1 - 19 of 19 Posts
· Registered
Ordering some CB stuff and, since I don't know anyone with a SWR meter to borrow, I was going to buy one. I know they are relatively inexpensive, but I also know you can spend any amount of money on anything and sometimes get a decent product or sometimes get a piece of crap. So . . .
Can anyone recommend a good SWR meter?
Thanks!
· Registered
Truck stop or cb shop Either one
· Made in the U.S.A.
· Registered
If a truck stop with a radio shop is close go there
sent from Skynet
And pay as much to have it tuned once as it would cost to buy the meter.
Buy a meter. Learn how to use it. The antennas do need to be adjusted periodically. You'll get a new antenna. You'll get a new rig. You'll switch antenna mounts. A friend will need one. Just buy one.
· Registered
sent from Skynet
I may have read that wrong. I'll give you the benefit of the doubt and assume thta you meant go there..............and buy a meter. Not go there..................and get your antenna tuned.
· Registered
Thanks!
A very quick google produced this.You will also need a short jumper coax with pl 259's.
http://www.cbradiosplus.com/product_p/1037.htm
· Registered
Discussion Starter · #15 · (Edited)
Thanks for everyone's suggestions.
Just a reminder though, that I am not really looking for sources, or where to buy, but rather which ones are not worth the money, are duds, pieces of sh**, etc. And which ones seem to work the best and are worth considering based on your experience with them. There is no shortage of places to get them, for sure!
· Registered
So can any CB/antenna combo be tuned with a SWR meter?
I installed my Cobra 25LTD classic with 4' firestick over the weekend and didnt tune it. It receives and sends fine as far as I know thus far but....
If so, what does the process of tuning your antenna entail???
· Registered
So can any CB/antenna combo be tuned with a SWR meter? Believe so
I installed my Cobra 25LTD classic with 4' firestick over the weekend and didnt tune it. It receives and sends fine as far as I know thus far but.... If your SWR is above 2 when you transmit there is a great likelihood you will damage (fry) your radio.
Check out the section SWR Testing and Setting. They explain how to use the SWR meter to tune a CB. http://www.firestik.com/Tech_Docs.htm
· Registered
Discussion Starter · #19 ·
1 - 19 of 19 Posts
