1 - 10 of 10 Posts
Could use some wiring help guys. I have the ace engineering bumper and the lifetime leds in the bumper. Want them to come on when in reverse AND switched to the Contura Rocker switch to be able to turn on manually (unloading camping gear at night).
Wired the rocker switch like i've seen and with the accessory lead from pin 3 into 85 on the relay. So switch lights work. To get into reverse I pulled the left rear light found the white/green and black ground going to the reverse bulb and tapped both. Ran the wire tap from white/green also into pin 85 on the relay and wire tapped the black ground on the reverse and ran to pin 86 of the relay.
It works. flip switch = light on. Put in reverse = lights on.
Hit the brakes and the damn lights lit up blinding everyone behind me last night driving home = WTF?
Any ideas? I'm wondering is it the grounding?
Random Dude
Put diodes inline in the 2 wires headed into the 85 terminal on your relay (so no backfeed)
and​
run a dedicated ground to your 86 terminal (so you don't piss off the CANBUS).
Should be good to go after that. Gotta' run to lunch, hope the quick reply did it for you.
EDIT: Move your 30A fuse to the wire feeding terminal #30 on the relay, and put a ~5A fuse going to the switch.
Size diode?
triangle symbol of diode pointing in the direction of the relay or towards switch?
thanks
Random Dude
Size diode?
I'd go with 50V 1A - plenty of safety factor there. If Radio Shack still exists, their P/N = 276-1101.
THIS LINK has all your diode orientation questions answered. If that doesn't work, HERE is a direct link.
thanks
:beer:
Gunnery Sergeant USMC (ret)
Ok, I won't respond to your PM since my reverse light is wired directly into the reverse circuit without switch or relay.
Random Dude
. . . my reverse light is wired directly into the reverse circuit without switch or relay.
Same here. I bought the diodes, then said "fookit" and decided to keep everything stupid-simple.
I figger'd that I can turn the key on and throw it in reverse (not running) if I need light out back (or use my rock lights).
Ok, I won't respond to your PM since . . .
:idea: - you should send him a PM telling him you posted in his thread telling him you won't send him a PM :laughing:
Problem solved with proper grounding relay to the tub. The harness/reverse black ground is a floating ground and was causing the crossovers. I appreciate the responses and will be adding the diode for the hell of it as I had already gotten then before trouble-shooting.
Jeep on
Jeep on
Did you get my PM telling you that I was posting in this thread and in this thread telling you I wasn't sending a PM?
:grin2:
1 - 10 of 10 Posts
