i would say the goldish one is ground, the other side is positive, and the middle one goes to the relay... i just wired other switches and they came with the same 3 legs in the same colors....
if you have a volt meter just check for continuity between the 2 gray ones with the switch in the ON position.... if they are continuous, and they are discotinuous with the switch in the OFF position, its like i mentioned above....
Gunnery Sergeant USMC (ret)
