Hi
I just realised that if I disconnect my sway when I am on the 2x4 the light on the dash blink, but not on the 4x4.
Is it normal or there's a problem, I assume that the sway bar does disconnect when on the 2x4.
Just wondering
Frank
that just means that you have in gauged the the disconnect. It blinks when in 2 wheel drive or when you are in 4 wheel drive and doing more then 14 miles an hour.
correct, IIRC the sway bar will not disco in 2WD, must me in 4WD and going under 14MPH or else it will just blink after you hit the button, right?
