1 - 1 of 1 Posts
I recently traded in my 2011 Dodge Ram QC for a JK, one of the best decisions I have made by far. And I have no use for the setup any more since I don't have any urge or plan to put and subs or amps in my Jeep so I would like to part ways with them to put towards fun offroad parts that I will actually enjoy. I am asking $350 for everything, box, both subs and amp. As far as I know it will fit from 2002 and Up.
Here are the amp specs:
Atom Series 1-Channel Class D Car Amplifier
RMS Power Rating:
4 ohms: 250 watts x 1 chan.
2 ohms: 400 watts x 1 chan.
1 ohms: 600 watts x 1 chan.
Max power output: 1200 watts x 1 chan.
Pulse Width Modulated MOSFET power supply for high power output and low impedance stability
Wired remote bass level control included
LED power (green) and protection (red) indicators
Variable bass boost (0-18 B @ 40 Hz)
Double sided circuit board construction
Soft Start Turn-on eliminates pops and clicks
1 channel operation
Speaker-level inputs with signal sensing for automatic turn-on
System protection circuitry (thermal, overload, and speaker short protection, and DC output)
Low profile aluminum finned heatsink for extreme heat dissipation
Custom tooled solderless speaker and power terminal blocks
High and low level line inputs
Nickel-plated RCA level inputs
Nickel-plated screw terminals
Variable gain control
Input sensitivity: 0.5-5V
Variable low-pass filter (40-180 Hz, 12 dB/octave)
Subsonic Filter (17-50 Hz, 12 dB/octave)
Damping factor: >150
Frequency response: 20-250 Hz
Dimensions: 11-3/8"L x 7-3/4"W x 2-1/4"H
4-gauge power and ground wiring is required for installation.
1 - 1 of 1 Posts
