You must make sure the amp our output source are 2 ohm or less, that is where you need to be. Wiring will be another issue, you'd have to check the wiring harness on your amp to see if there are available connections and/or check a schematic of the wiring coming from the head unit. Chances are you can't...no really sure. I would make sure the above is correct or checked first.
You must make sure the amp our output source are 2 ohm or less, .....
The infinity sub has 2Ω dual coils, thus can be wired up in series for single channel 4Ω load if the amp can't push 2Ω, just don't expect anything ground shaking out of that sub one way or another.
