I put the bumper from my jeep onto our other Jk ,can i wire them up without some type of factoy setup or do I need to order a factory harnss and new lever for the steering column,i would like to just wire them up and just put a switch some where.
i dont see why not. i would just put them on my own switch. to buy a new stalk with a fog switch would be pretty pricey.
Yeah easy.
Just run a bosch relay to a switch and you'll be good.
I put mine on the driver side dash under the air vent
Did you guys tap into anything for power?
I just got a new front bumper and fogs, and going to wire them in, but probaby not on a switch.
I want to tap into the low beams (green wire on headlight bulb, correct?) or the parking lights.. I don't mind that they are always on.
I'm going to tap into battery - to relay, and the relay to ground and tapped power.
Has anyone else done this? What thoughts or lessons learned have you?
Thanks.
