1 - 10 of 10 Posts
Ok. So I'm running this through my head, and want to see if I'm crazy, or if anyone's done this. I'm looking at picking up some Prothane or Energy Suspension poly bushings for my sway bars. They're cheap, so worst case, I burned $30. Anyway...
I want to gain a little more stability and more predictable handling on-road without losing anything off-road. For the front, I have no worries, as I'll have it disconnected off-road. For the rear, I'm THINKING that the reduced flex in the swaybar may actually help stability. However, I'm concerned that stiffer bushings may cause a reduction in flex. Anyone got any words on this? Thanks :) Mark W.
The flex comes from the sway bar, not the bushings, so it shouldn't make any difference to the flex. I'd be surprised if you could notice much difference on the road, but it's worth a try.
Discussion Starter · #3 ·
That's what I'm figuring. I just wondered if the swaybar being able to deflect less would cause any degradation in off-road flex/articulation. As for difference, I doubt it'll be anything big, but every bit counts :) Mark W.
I'd say this is definitely something worth looking into, not so much from a 'performance' standpoint as just failure.
my bushings on my original stock e-disco were mashed into nothing at about 40K miles.
I was going to look into replacing them but Zack Massey gave me his e-disco after he blew it up and went to antirocks to keep my canbus hack/bypass experiments going.
His only had a few thousand miles on it so the bushings were still good - but it's only a matter of time.
Poly swaybarbushings would make a huge difference. I did them on my 5.9 and it was night and day
Discussion Starter · #7 ·
OK- update! Just got these suckers installed. The rear was EASY- just an A->A swap. The front required cutting the bushings off, which sucked, but so it goes :)
Anyway, driving impressions- HOLY SHIT!
Yeah, nothing major :) As expected, but I did notice a small improvement in squish/squirm when transitioning (left turn to right turn, and so on)- no appreciable increase in NVH (Noise, Vibration, Harshness), or any downside except the $30 spent and time in installation :) So, I'm happy :) Mark W.
Thanks for the input, it got me curious.
Discussion Starter · #10 ·
^ Exactly. I figure that I could weld the damn front on for all I care, as it gets disconnected when I wheel :) Mark W.
1 - 10 of 10 Posts
