TL/DR: First Start Here
Walk-around @500 miles and short rev in the driveway: https://www.jkowners.com/forum/showthread.php?p=4470114
This might be the second or third hemi swap thread with a manual transmission out here, so hopefully this will be useful to some of you out there who refuse to slushbox your hemi haha. I’ll try not to duplicate too much from other threads because if you’re seriously considering this project, you’ve probably already read and re-read all of the others (you know you have).
So why a hemi, why not LS? It all came down to the stick. LS engines are mostly limited to the NV4500 which some have said is a little truck-like, especially with its low 5.61:1 1st gear (stock NSG370 is possible, but you’d need a TJ bellhousing and the trans is fairly weak anyway). The Getrag 238 is geared similarly to the NSG, and even though their input torque rating (300 lb-ft [EDIT: torque rating might be closer to 400 lb-ft, hard to tell, limited info...]) doesn’t inspire confidence behind a ~500 lb-ft hemi, I haven’t seen very many complaints about failures online.
Here’s a list of the things I did that you may not have seen before:
•Group 31 Odyssey battery, with Odyssey battery hold-down bracket kit
•4/0 cables for the starter-to-battery, alternator-to-battery, and engine-to-battery ground
•Oil catch can
•3.6 JK fan conversion (and mods to make it fit!)
•AEV snorkel (and DIY coolant reservoir)
•DIY lower radiator hose
•SRT / Hellcat exhaust manifolds
•True dual exhaust with: Magnaflow 59959 catalytic converters; Yonaka 304 stainless bellows flex couplings; Magnaflow 10792 x-pipe; Vibrant 1795 bottle resonators; Spintech 9000XL Super Pro Street mufflers; and Nameless Performance double-walled exhaust tips.
…And also some other mods:
•Teraflex 2WD Low TC conversion
•Rock Slide Engineering TC brace (modified for stock rear driveshaft)
•PSC pump, reservoir with large cooler
I’d recommend having a second driver while you’re working your swap. My project started in January 2017 with an engine purchase, the Jeep has been in the garage since February 2018, and as of late November I still have maybe another couple of months to finish the exhaust. I spent many hours doing other things, you know, while I had the access. Things like a front axle rebuild (new u-joints, added a truss, new unit bearings, added anti-flop tie rod joint caps), transfer case mods, hood vents, lots of diy mods etc. Although, if I didn’t have the second car, I probably would have finished it in a week or so haha. Choose your poison!
•Oil catch can
