Steering stabilizer relocation???
22K views 25 replies 21 participants last post by  JeepUpKeep37s
#1 ·
anybody have any ones they recommend, worked good, or bad and to avoid?
#2 ·
If you like messing with stuff, i made my own for about $8 depending on what length steel you have to buy. Drill three holes in the plate, none on the jeep.
#5 ·
I have the Kilby one. Needed elbow grease squeezing my TF SS into the bracket, but it does it's job. $30.
#7 ·
What's the benefit of relocation? Up out of the way?
#18 ·
Just installed this last weekend..w stock SS, however, after install got a lot of wandering left to right, and for some reason needed to mess w centering my wheel again!!??!! Did not adjust track bar (RK) or anything else..disconnected the SS last night and still get a gentle drift to the right. Do have a 3" spacer kit on and noticed recently the driver/front spring bowing more than usual (forwards)..is this somehow affecting my alignment? all help appreciated. thx
#11 ·
from the factory, the steering stabilizer hangs way down in harms way, doesn't take extreme wheeling to customize it in a bad way.
Any of the relocation kits will get it up above the tie rod and make it live a lot longer.
The poly kit is beefy, well designed and easy to install - just put one on cjb321's jeep as part of his poly stage 3 kit.
I made my own very similar to theirs a few years ago - one of the first fabrication projects I did on my rig.
I've been kicking the idea around about making one similar to ORO's - they move it up onto the drag link, at least until I go hydro :D
#15 ·
I am having the JKS (OGS162) one welded on this week. When welded on it also reinforces the trackbar mount which is something I was trying to accomplish as well. Using the Poly tie-rod clamp on the other end of my TF SS.
#17 · (Edited)
I dont have "poly's" but I built one very similar when they had the stud design, looks to be similar dimensions. i have no additional bump stops. The stabilizer will hit frame and dent it on full compression. Not that I've ever done that or anything lol.
Sent via paper airplane
