I took this problem to the dealership, but they pulled the 'is the check engine light on? if not, we can't do anything under warranty...' card...
Here's the problem:
Every so often, when I start my jeep, it takes about 4-5 times to actually turn over completely. The engine will rev up to about 700 rpm and then just die. I thought that it was a) the a/c compressor wasn't disengaging when I shut the engine off, so it was putting too much pressure on the engine on start up (so i had a friend start it up while I watched the compressor, and it wasn't engaging until about 5 seconds after start-up). or b) the battery (even though it has enough power to start up 99% of the time and even enough to start it up when the problem happens, just not fully turn over until the 4th or 5th time) but my battery seems to be just fine.
I called the dealership and he said that it could be a exhaust sensor... ??
Sorry if my description is a little short, but I don't know how else to describe it! Any ideas/help would be awesome!!
Thanks y'all!
Here's the problem:
Thanks y'all!
