1 - 10 of 10 Posts
Hello everyone I have a few Questions that I am hoping somewhere on here is able to answer for me. Recently I was driving down the highway when my Cruise control went out and the ABS/Traction Control lights on my dash lit up.
I ran the codes and the codes came back saying the Front left/Rear Right speed sensor's were out. I replaced both myself and to my surprise they were both completely broken and the rear one was broken in half.
Anyways after replacing them I was hoping it would just make everything normal again but of course it didn't. Was looking online for some more information but the best I could find was it should have worked and maybe try and unplug the battery for awhile then hopefully it works. Nothing so far has worked and I am delaying going to the dealership as long as I can but I need to figure this out sooner rather than later.
If anyone has something I can try rather than dropping some cash at the dealership that would be great. Also in the Military so we have a full auto shop with pretty much everything you could ask for on base so getting tools shouldn't be an issue.
You have to clear the codes then everything will work again.
Sent from my SM-N910V using Tapatalk
I'm dealing with this too atm. As you've already concluded, you can't just clear those types of codes. Mine is showing a U1418 code ESP/ BAS lights are illuminated. I also unhooked both pos and neg batt terminals overnight... no dice. With my particular code there's several potential culprits.. hub bearing, tone ring, speed sensor(s), alignment, even possible clock-spring ( which would suck as I've recently replaced that with no issue ( under the recall = parts reimbursement... although not sure they will cover it if I have to replace it again).
Idk... If you haven't already, I would look to see that your other sensors are okay and also make sure that there wasn't collateral damage to the speed-sensor lines/ connections.
  • Like
Reactions: DocGorgeous
What other sensors would I be looking for? And would you just think it would be about time to just take it into the dealer and eat the cost?
The other two wheel sensors... even though that code doesn't indicate that those are in question. I would simply check t o make sure they're okay... since the others were toasted. Again... even though an issue with the other wheels may not be reflected in the particular code that you brought up... Piece of mind.
Also even though you didn't mention it... make sure to put maybe 10 or so miles on the odometer after repairs like this. Not sure in this instance but it could require putting some miles on it for the computer to recognize the repair and update, subsequently shutting off the dash-lights.
Up to you on succumbing to the dealership. In my personal experience, many fixes ( had my JK going on 10 yrs now... lots of little repairs lol) aren't that difficult to remedy once you have isolated/ diagnosed the problem... just a PITA to track down sometimes. If you trust the integrity of your delership's service dept, then by all means let em have a go at it. Unfortunately what has kept me from relying on my local dealership, is the fact that they are seemingly somewhat incompetent and unethical. That's why in most cases I would rather do the repair if I'm able.
  • Like
Yeah one thing I loved before i bought my Jeep was being able to work on buddies ourselves and not having to take it to a dealership. I have driven about 100 miles or so since repairing both of them so I know it isn't that unfortunately. I will check on those 2 other sensors tomorrow after work to make sure it isnt those as well. Thank you
Without a scanner it can be difficult to repair electrical problems. I had a code once fore a wheel speed sensor, replaced it only to still have the code. I wound up finding a broken wire a foot and a half away from the sensor. No ideal how the wire broke.
Is it as easy as tracing the wire back and then replacing it or is in more in depth than that?
It can be that easy. That's why I was saying to check the connections... not just the sensor at the wheel but back along the line to the connectors.
1 - 10 of 10 Posts
