1 - 20 of 24 Posts
With the soft top on and latched down it is still about a 1" from being flush with the front of the windshield. Does anyone else's look like this? I haven't had a chance to roll down to the dealer and cruise their lot to double check.
I've never noticed it being that much of a gap until this past weekend when rain poured in to my jeep. Any help would be appreciated.
I throw a pic up later.
Thanks
Wow!! I'm not even close. I'm 1 1/4 inches from where you're at.
to the garage I go.
Thanks for the pics
Attach the front first, then, stttreeeetch the rest of it back. I did it in the sunshine, 75f+, but you should be able to start from the front, and work it back. Luckily the camera was ret to roll, and it was still light outside. I got the jeep hitched up to the jetski for some surf action tomorrow am.
Got it within 3/8 or so. Taking it in to the dealer to morrow to inquire about the steel header I found a part number for. Too many guiness to keep messing with it tonight....kept eyeing the rubber mallet
My experience with the softtop is that it's pretty easy, but if you're not familiar yet, it's easy to get it misaligned. If it's not matching up, you may not have it seated correctly on top. My first top would do what I wanted, so I tried to encourage it a little and it ripped.
Discussion Starter #10 (Edited)
Mule,
Are you talking about the front latches or the ones where the sunrider latches?
I had alignment problems too. When I did it in the correct order it lined up better ,found instructions on youtube
YouTube - OPERATING A SOFT TOP UNLIMITED 4 DOOR JEEP WRANGLER
Thanks for the video
None of my zippers pull that easy. I'm off to the dealer to see what they have to say. Plus I'm picking up some rescue green paint.
edit added....
Went to the dealer to do a couple things....
1. Ask them to flash the comp to adjust the spedo/odometer for the new tires I put on. The "service manager" asked me what size. When I told her 33s she said they could only go up to 22s??? After some explaining she got it through her head that I didn't need my 33" rims balanced. She said she didn't know if they could do that but thinks someone at some time might have came in and asked the same question but she wasn't sure of the answer.
2. I asked about the gap on the front of my soft-top. Showed her where it didn't line up and that the leading edge sticks above the front of the windshield. Told her avout the wind noise and the indoor waterfall action I get when it rains. She gave me two possible solutions both were jaw-dropping stupid.
-The first was the top fits like it is supposed to and the 1/2 inch gap was normal. :pissed: I had purposly parked next to a Wrangler with a soft top on their lot. I asked that we walk over to it and look at the fitment on that one. We did and guess what? I lined up perfectly with the windshield.:thefinger:
-the second was that some jeeps aren't designed for a soft top and that was probably my issue. I assured her that mine was designed to have a soft top and showed her the sticker. She said that she still needed one of her techs to take a look at it. Conveniently, none were in today.
I'm taking it in Monday to show a tech and hopefully get some better service.
Dizug-I'm sorry, I jumped in & was talking about the bikini top bridge. You definitely have a fitment problem on yours as its not even sitting in the gasket properly. Hopefully a tech will fix it. My salesman happened to be super knowledgeable about jeeps, as he is on his second one for the past 18yrs.
Finally got some pics of the top.
The gap on my 2dr I just bought looks exactly like yours. Mine does not go flush like the first pics. Hmmmmmm
I have had this problem also (usually after using the sunrider option). Check your back C pillars and see if the cloth is seated into the groove on the tub. I have found that when using the sunrider the whole soft top can move backward making it very difficult to put the windshield latches back.
My fix is to pull the velcro on the side windows and push forward on the back of the soft top. This will move the top more forward and the latches will seat properly and pull the top.
I'll have to play with it tomorrow .. it's raining right now. I do notice that my passenger side fits more flush than the driver side ... 1/4 inch gap on passenger side and 3/8th on driver side ...
The last time I messed with the top I did only have the Sunrider open ...
Discussion Starter #16
Took the Jeep to the dealer today. My build date is outside the what the TSB covers but after some convincing but they "found a way" to apply it. Should be replacing the seal at the top of the windshield and the header unit.
I can pick it up tomorrow. I'll let everyone know how it works.
Discussion Starter #17
Screw'd o de Mayo
Picked up the Jeep this evening. Dealer called me @ 1645 to say it was ready. They close @ 1800 so by the time I got there all the techs had went home.
Right away I could see that the gap was still there. The write up said they replaced the header gasket and from the smell of adhesive and coffee mug rings on my hood, I knew they had done something. I told the service manager that the gap looked the same but I'd get it on the road and see what it sounded like.
Drove off and even at 20mph I could tell something was off so I pulled over in a parking lot. Found the dealer had put the door surrounds back but they didn't put back in the bolts that hold them in place on the roll bar. I called the dealer and the service manager told me the tech that had done the work was gone and asked that I bring it in tomorrow. I said no at first but didn't feel like leaving it for another night so they threw in an oil change.:thefinger: I'm normally fairly chill but this is a little ridiculous.
I can't really tell if what they did fixed it because without the door surrounds being in the right spot it kind of throws the whole thing off. I'm kicking myself in the ASS FOR NOT CHECKING CLOSER BEFORE I DROVE IT OFF THE LOT. :nuke::nuke:
Top showing the misalligned door surround
Passenger side view
Driver's side showing the new and improved header gasket.
Dude...is there another dealership even remotely close to you? Sound like a change in atmosphere is in order.
I played around my top today ... loosened up the top and fully latched it first before putting everything back together. Although the official JEEP video says that installing the top will be harder if not impossible if you latch it first ... I did not have any issues. Perhaps not having issues proves something isn't right?
The passenger side pretty much goes all the way to the edge of the windshield gasket with just about no gap. The Driver side still has maybe a 1/4 inch gap.
Even with with the latch fully closed and the sunrider latch open (I thought maybe the sunrider latch was preventing it from fully seating) the gap does not change. I can only assume that the windshield gasket is not installed 100% straight causing the bigger gap on one side than the other.
It does not leak so I'm not gonna mess with it anymore ...
I did not watch the video, as the manual spells out a simple procedure, and if followed when the top is above 70f, then attaching the front FIRST, then streeetching back is the preferred method. I tried it attaching the back first, and it does not work correctly, as it ends up too short, like the pics (I had a few pints in me, so I wasn't on my game baby).
1 - 20 of 24 Posts
