1 - 2 of 2 Posts
****SOLD****
New never installed Smittybilt XRC rear bumper with hitch and tire carrier. The tire carrier has been installed but has absolutely no signs of wear. The tire carrier comes with a brand new latch assembly. Bumper is still in the box I have not removed it so I do not have any pictures.
Prefer local pickup in Las Vegas
Asking $700
Part Number: S/B76856
2007-11 JK Wrangler, Rubicon and Unlimited
2 and 4-door models
Manufactured from 3/16” cold rolled steel and then robotically welded to the exact specifications
Features pressed tapered 2” diameter bearings, reinforced double sided gussets
1-1/4” grade 5 mounting hardware
The XRC Bumpers have high degree approach angles and raised corners to maximize ground clearance. Manufactured from 3/16 cold rolled steel and then robotically welded to the exact specifications. Solid mount D-rings that are welded on the inside and outside. Welds are ground down and smoothed out, then a two stage textured matte black powder coat is applied for the ultimate look. The front stinger is 1.75" tubing and has two light tabs that can hold up to two 9" lights. It’s unique design is capable of mounting up to a 10,000 lb. winch with the option of running an aluminum or roller fairlead. Rear Bumper features a 2 receiver hitch and two D-ring mounts. Tire carrier features pressed tapered 2" diameter bearings, reinforced double sided gussets, 1-1/4" grade 5 mounting stud, adjustable tire mount to fit a 31-40" tire. Speed latch with removable lanyard. 2 receiver hitch bolts to factory OE mounting points. Each bumper is developed to be a complete bolt on and requires no modifications to the vehicle.
I'm looking to buy one of these in the next 3 months. I wish I was closer to you. If you don't sell it and want to work out something for shipping, let me know.
Good luck with the sale.
1 - 2 of 2 Posts
