What exactly makes the pricer bumpers better?I had their front and rear bumpers on my old rig.
However if you ever see Shrockworks, LOD, Poison Spyder, Evo, etc bumpers you'll understand why they're much more expensive.
What do you mean?The second issue is the weight. I installed a budget boost before the bumper and winch and the rake was not there, after they were installed it came back. Other than that it has been very nice.
CHINA...are these made in the US or the four letter word (CHINA) ?
What do I mean by the rake coming back? With the stock bumper and no winch the lift I put on had the jeep sitting level. When I switched to smittybilt and winch the front sat about an inch lower so the factory rake was back. My guess is that bumper and winch combo probably weigh nearly 150lbs. So stock springs are going to compress a bit under the weight. I think it is to be expected. When I go up to a RK lift I think it should be level again.What do you mean?
Ahh, makes sense. Im riding stock lift right now, so I can assume it will sit lower in the front then it already does stock. But I wont be running a winch till 1. I cant decide which to go with, and 2. till i get the funds. I was thinking an engo syntetic 9kWhat do I mean by the rake coming back? With the stock bumper and no winch the lift I put on had the jeep sitting level. When I switched to smittybilt and winch the front sat about an inch lower so the factory rake was back. My guess is that bumper and winch combo probably weigh nearly 150lbs. So stock springs are going to compress a bit under the weight. I think it is to be expected. When I go up to a RK lift I think it should be level again.
Yeah, i saw your pic a few days ago, loved it, actually had a question about your RI lights, did you run those to the stock fog light harness? Thats something i wanted to do instead of running the wiring harness all the way to the battery and running the switch wire.The one on my Jeep is quite nice and has proved to be solid, quiet, and problem-free:
Sorry if I missed the question in the other thread. It fell off the front page and... oops. :flame:Yeah, i saw your pic a few days ago, loved it, actually had a question about your RI lights, did you run those to the stock fog light harness? Thats something i wanted to do instead of running the wiring harness all the way to the battery and running the switch wire.
Yeah, i thought about the SPOD before, Im currently using the daystar switches near the shifter. how much modification is required for the SPOD ie. drilling, wiring, entire installSorry if I missed the question in the other thread. It fell off the front page and... oops. :flame:
Originally had them wired to a switch inside the cab. Ended up getting an SPOD and now they're wired to that.
The factory fog light harnesses are still in place, but I packed the ends full of dielectric grease and then sealed them with some 3M electrical tape. Not sure if I'll ever use them for anything, but didn't want them to get trashed in the meantime.
With the RI lights being low-voltage LEDs, you might be able to get away with it. I haven't read any reports of folks trying (even though I'd bet someone has).
That's the beauty of it. Practically none. No drilling at all. Only "modification" I had to make was a small trim of the cross-panel above the rearview mirror where the switch box mounts. The rest of it is just running the wiring harness. Screwing the "brain" to the underhood mount is a piece o' cake.Yeah, i thought about the SPOD before, Im currently using the daystar switches near the shifter. how much modification is required for the SPOD ie. drilling, wiring, entire install
Sounds awesome actually. Just got wait for the price, lol.That's the beauty of it. Practically none. No drilling at all. Only "modification" I had to make was a small trim of the cross-panel above the rearview mirror where the switch box mounts. The rest of it is just running the wiring harness. Screwing the "brain" to the underhood mount is a piece o' cake.
Once installed you just wire your accessories to the underhood unit and presto.
I completely agree, I hate the SAME look everyone goes for. But the issue is, MOST bumpers ive seen on the market look stupid. I love the look of the R-SE front bumper, but at $1,300 and the fact that it limits wheel travel, i cant really go for that. The smitty actually looks good...Plenty of other bumpers out there in that price range. One thing I hate about shittybilt is every mall crawler that gets Quadratec magazine has one. I prefer to be a little original with my jeep so it doesn't look the same as everyone else. Just my 2cents
