1 - 1 of 1 Posts
From now until May 31st
Receive a cash back rebate on 4 Hydro, Nitro, or Monotube shocks!​
Nitro Shocks - $35 Mail-In Rebate
Skyjacker Softride Nitro shocks are 150 PSI Nitrogen Gas pressurized and feature multi-stage velocity sensitive valving, twin tube construction, oversized piston head, internal rebound bumper, 5/8" diameter hardened double chrome rod, urethane bushings and compression control which prevents the formation of air bubbles to reduce fade. Skyjacker has set a high standard of uncompromising quality in the development of this high-performance shock absorber.
Hydro Shocks - $35 Mail-In Rebate
Hydro 7000 Series Shocks are recommended for multiple shock applications and mild to moderate off-road use. Skyjacker® Hydro 7000 shocks are hydraulic action, have multi-stage velocity sensitive valving, twin tube construction, bonded iron piston, chromed piston rod with micro pores, come with red polyurethane bushings, includes red shock boot, and come with a limited lifetime warranty.
M95 Shocks - $55 Mail-In Rebate
Skyjacker's new M95 Monotube Shock is the ultimate shock absorber for light trucks, Jeeps and SUVs. This single tube design helps operating temperatures stay cooler under extreme conditions. The high pressure nitrogen gas and floating piston technology combine to create the fastest responding shock ever.
Skyjacker produces one of the best suspension lift kit systems and components in the world. Whether you're just a road warrior, looking to lift your Jeep to accomodate larger tires for that aggresive look, or a hardcore off-roader wanting to completely rebuild your Jeep suspension to become a rock-crawling machine, Skyjacker Jeep Parts Lift Kits are a perfect choice.
Most Skyjacker lift kits come with the option of Nitro Shocks, Hydro Shocks or no Shocks so you can customize your Jeep the way you want.. Morris 4x4 Center offers a full line of Skyjacker lift kit Jeep accessories, from pitman arms, sway bars, traction bars, tie rods, shock boots and much more.
Skyjacker Shocks 2015 Mail-In Rebate
1 - 1 of 1 Posts
