1 - 9 of 9 Posts
Hello guys im looking to add a little more suspension lift to my jeep by getting coil spacers. 3 inches or slightly less is where I want to be at, I currently have 1.5 via springs and looking to add another 1.5 via spacers. I don't like to cheap out on my jeep but I can't find anyone that sells 1.5 or 1.25 coil spring spacers outside of ebay (if there are please link me!) I would consider springs if reasonably priced but preferably would like to get a good brand spacers like teraflex but there is no such thing in the height im looking for.
Which brings me to the question, should I buy the coil spring spacers from ebay? I picked out the highest quality options i could see and here are the links: let me know what you think i just wanna order them and install them before winter. One option is steel and the other is aluminum? I have never seen aluminum spacers before. Also the aluminum one mounts under and not above the spring in the rear, the front is normal.
Steel front:
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/251731719498
Steel rear:
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/181958941005
Aluminum front:
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/111795770170
Aluminum rear:
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/111798453615
Thank you so much
There is a reason there aren't any from Teraflex, don't know what it is, But.... At three inches you need control arms, they usually come in sets with springs. Not to be an ass, but not doing a real lift to get three inches is being cheap.
Sent from my Pixel using Tapatalk
Im sorry i didnt specify anything else. I was asking about these spacers in general. I have shocks rated for up to 4 inches of lift. Extended brake lines. core 4x4 lower and upper front adjustable control arms. Core 4x4 front adjustable trackbar and a teraflex rear trackbar bracket. I can run 3 inches of lift. I just did a 10a spring swap first, saved up to get the parts that i wanted and now im looking to retain my springs and add 1.5 inches of spacers.
Gunnery Sergeant USMC (ret)
Idk i guess im not patient enough plus i have 10a springs, just looking for a little more.
Be patient, do it once and do it right that time.
While I concur that the 3" coilspring lift is the best option should you seek that amount of lift, several years back I had OEM Rubi (18/59,iirc) coils on my 4 door '11 ...I needed the same height you seek so to attain 1.5" I had 3 x 1/2" TeraFlex spacers stacked up top on front coils
I've also used different rear spacers - example being a .75" ,retaining spacer from TeraFlex with an additional .50" under it ...I've used all manner of spacer , mostly acquired over time for multiple Jeeps ...and Ithink most came from several TF levelling kits or garage sales , friends , etc.
I have 8-10 x TF polyurethane spacers in various sizes , both front and rear.
I again , recommend coils but if you wait until I get back home next week I'll check to see if i have what you need & we can work out some cheap arrangement for you to get what you need for the height you require .I'd shoot me a PM so I remember. Fwiw, I'm in Nashville ...I can't imagine the weight for shipping being over 3-4lbs max,if you want to check options.
( I have , like , 3 of the Teraflex levelling kits laying around ( 1 is brand new & never used ) , multiple "eBay" PU spacers ( Mnt Goat , I think ) and lotsa other lift related HW that I don't use just stored in my garage .. ....)
Jeffery
:jeep2:
if you like how your coils feel right now then add an 1" spacer. It saves money and is an easy hour or two swap in your garage so if you can do the work you are not out anything if you dont like how it performs.
Thank you all for your advice and willing to go out of your way @jeffery, i ended up getting the rock krawler 2.5 inch tripple rate springs both front and back. Figured for the 300 dollars id be getting a lot for my money, they net exactly how much i want, they wont sag much when i armor up even more. They ride very good from the reviews i have read and they flex well due to the triple rate design. Again thank you so much and im glad im gonna be getting these springs on.
1 - 9 of 9 Posts
