Jeeps are meant to get dirty…. but not stay dirty.
Pampering your Jeep is so important. If you are going to name your Jeep you better take care of her.
The three areas of the Jeep Soft Top you should concentrate on are the fabric, the windows, and the Zippers.
Keeping your soft top clean, and making frequent inspections, will help prolong the life of it.
There are several trusted brands of cleaner out there.
I have used the Bestop products on my Jeep and found they are simple and easy to use. –They have a Cleaner, Protectant, Polisher.
When I can’t these products I just use water. Chemicals on the soft top are not good.
  • Never use bleach, detergents, ammonia or alcohol-based products, stick with the products specifically made for the soft top.
  • Clean it monthly, and don't forget the inside.
  • Make sure you keep those zippers clean too. Just some regular mild soap and water will keep dirt from building up on your Jeep's zippers. If you let dirt and grime build up on your soft top, windows and zippers, it will ultimately lessen the life of your soft top.
  • You hear a lot of people recommending the Pledge spray polish, the regular not lemon, on Jeep Windows. I suggest you avoid this tip. I hear over time it will cause your windows to turn yellow.
  • Can I take my Jeep through the car wash? First if you have a lifted Jeep with bigger tires some car washes will refuse you. Those automatic car washes work, but are not a good idea because the high-pressure sprays and rotating brushes will force water into the vehicle. Taking your Jeep soft top through an automatic car wash could scratch the Jeep’s windows and might even tear the seams. Plus, some of the chemicals can cause irreversible damage to the vinyl itself.
  • Those zippers can be tough to zip on and off. I have used a zipper lube in the past, but some say that lubrication attracts dirt and grime. Some Jeep owners carry a small bar of soap in the glove box and rub the bar of soap directly onto the zipper itself, it will lubricate the zipper without attracting as much dirt & grime as the spray lubricant
  • A must for your zippers…. is zipper pulls on your Jeep’s windows. This allows for easy grasping and pulling. There are several places online you can purchase paracord zipper pulls or it you are crafty you can make your own. The cool thing about this is you can make them in a color to match your accessory color. My purple paracord zipper pulls allow me to work the zipper much easier now
    Joint Hand Hairstyle Arm Shoulder
  • . View attachment 366475
Thanks Tammy. I was unaware that people washed their jeeps, other than removing mud.
