1 - 2 of 2 Posts
I have a 2013 Jeep Wrangler it was parked and locked when I tried the key fob nothing happened I figured the battery was dead so I unlocked the door with the key and the alarm runs it 5 min cycle. I tried disconecting the battery even replaced it. The fob and the door will lock but will not unlock.I see there have been similar post but no real reported fixes. I suspect module failure. Has anyone tried reprogramming?
Try disconnecting and reconnecting all the harnesses to the TIPM. Otherwise maybe a bad TIPM. I'm assuming this happens regardless of which keyfob you use.
Not sure if you ever cruise with your doors off, but if you do, sometimes a loose connection on the door harness will cause weird things to happen. In my case, the side view mirror would only move up/down but not left/right so I unplugged the harness, reconnected, and all good.
1 - 2 of 2 Posts
