That's where I saw it in the factory service manual. Does the reception for everyone else suck too? It fine if your out in the open, but driving by a tree it will cut out. I have Sirius my truck that never cuts out.My antenna is mounted in the middle rollbar section, just to the right of the soundbar. Pull off the rollbar fabic, you will find it.
Mine cuts out when I go under highway bridges for a split second but works in my garage. Go figure!That's where I saw it in the factory service manual. Does the reception for everyone else suck too? It fine if your out in the open, but driving by a tree it will cut out. I have Sirius my truck that never cuts out.
The GPS receiver is the one under the top of the center stack togeather with the compus.I think is located in the Dashboard. Im not sure but ill look around and confirm that info.
Probably the rebar in the bridge...partial faraday cage.Mine cuts out when I go under highway bridges for a split second but works in my garage. Go figure!
