1 - 20 of 103 Posts
Vendor
We carry the full line of Rugged Ridge products for your Jeep JK. Call 706-559-9609 to order!
Bumpers/Steps
Exhaust/Intake
Exterior Accessories
Heavy Duty Parts
Interior Accessories
Recovery Gear
Seats
Soft Tops
Storage Racks
Suspensions kits and parts
JK Covers
Wheels
Winches
BUMPER BASE XHD FRT WINCH JK
The XHD Short Base comes in two designs; Integrated Winch Mount for use with almost any aftermarket winch (including the new Warn Power Plant with optional mounting blocks #11540.15) and Light Mount Base with two light mounting locations. The Short Base attaches quickly to the frame with two enclosed D-Ring mounting brackets. This four bolt frame mount design provides the toughest bumper attachment found anywhere while creating two overbuilt pull points. This bumper mounts close in on the frame rails, drawing the bumper closer to the body and increasing the approach angle. The narrow overall width gives enormous clearance for the front tires. Each Short Base includes two protected cut outs for your JK's factory fog lamps. Built in euro-guards protect the fog lamps from the elements while creating an easy mount point. Each Short Base includes side filler plates to close off the ends for a finished look.
Thanks,
CCOR
706-559-9609
Vendor
Discussion Starter · #2 ·
Outfitting a trail rig can add greater strain to the electrical system. Adding on a winch, air compressor, fog lights, driving lights, a spotlight, electric fuel pump, and a stereo amp can really tax the battery. A great way to combat that strain is to install dual batteries. This is especially true when using a winch, which can draw big amps for an extended period. These kits are designed to mount two batteries in place of the factory single battery location. The trays and brackets feature a black powder coated finish. These are mounting kits only and do not include any wiring. A suggested wiring diagram is included. 70- 95 CJ & Wrangler kits place the batteries side-by side and may be used with lead acid or cylindrical style sealed gel cell batteries. 97-06 TJ Wrangler its stack the batteries and are for use with cylindrical-style sealed, gel cell batteries only due to the battery mounting direction.
Thanks,
CCOR
706-559-9609
1 - 20 of 103 Posts
