1 - 9 of 9 Posts
This is a Rubicon Express Long Arm setup for a JK. I had this on my 2014 Jeep Rubicon for 1 year. There is nothing wrong with them I just put in new wider axles and changed all the suspension when I did it. I have all 4 lower arms, the 2 rear uppers, front drag link and front track bar with bracket. You would need to buy the brackets to mount the arms to the frame. 4wheel parts sells them. this is a huge savings if you already have a lift and are looking to do a long arm upgrade. The bottom links alone are $550 each. Links are made out of .250 wall chromolly.
Here are the parts you need
Front cross member RE4521 $430
Rear Frame mounts RE4525 $206
Located in Las Vegas NV
Asking $950
Thanks Jerry 712-253-7583
Did that kit also come with the heavy duty cross member that the front lowers attached to? I'm extremely interested, I called RE and can get all the parts ID need to complete the kit. Do you not have the front uppers?
The front uppers are not available because i still have them on my Jeep
1 - 9 of 9 Posts
