Hi i was looking at getting rubi shocks, coils for my wrangler x and i was wondering how much of a lift if any will it give my x and if i need to do any special mods to get them to fit thanks
Welcome to the forum!
You would not need to do any type of modifications to mae them fit. There are different spring rates so you may see a minimal lift but otherwise it should be about the same, maybe a little better ride.
may be a little bit of work for the outcome...where you wanting to lift your rig or did you just come across a set for cheap?
I doubt you'll get any lift. It would be a lot of work for not much of a result. I believe the Rubicon shocks and springs will give you a firmer ride from what I've read elsewhere.
I have a set of Rubicon springs and shocks with about 3,500 miles (~5600 km) sitting in my garage. If interested, maybe we can work a deal.
Discussion Starter · #4 ·
hey thanks
I found a set off a guy around here and its pretty cheap i was just wondering if it would make my ride any better i just put a set of toyo open country mts on 33 inch on a 16 inch rim and I was just looking for somthing to make it a bit taller and a better ride
Pm'd you
I am about to install a 2.5 Rough Country BB. I also got a set of Rubi Unlimited springs for my 2 dr X. When the lift goes on the springs will too. Then at least I have a REASON to take my springs off...lol...:bounce:
