1 - 9 of 9 Posts
Anybody run these? I like the looks of them online, but it seems like when you open the door, it would hit the mirrors. Doesn't that create a problem?
I haven't had my door hit one yet, just keep the limiting straps on.
I run em too-- the door opens just shy of the bracket.
My issue is that I am short. The A post gets in the way of my direct line of sight for the passenger mirror in the RR bracket. I have to use the OE passenger door bracket with the door on.
I keep a Craftman T-30 driver in the glove box; I move the mirror before I take the door off. Its a 2 minute detour.
The door has never hit mine, either. I only use the drivers side relocation bracket. In Maryland, we only need a mirror on the drivers side. If you use the passenger side bracket, it is hard to see with the door on.
Ok guys thanks for the info. I'm ready for Spring to get here!
Sent from my HTC EVO using Tapatalk
It's hard to see out the passenger side w/o shifting your body to see the mirror which will be half hidden behind the A pillar when you're seated in your normal position. Just so you know.
1 - 9 of 9 Posts
