I bought it new and its still in shipping packaging. , I’ll sell it for 160 shipped… it’s a beast of a tie rod.. a beast. Retail is 180 + shipping.
Located in Orland Park, IL
Here is some info on it:
The Rock Krawler heavy duty Tie Rod for the Wrangler JK is simply the strongest tie rod on the market! This bad boy is made from 1 5/8 inch diameter solid alloy treated steel and is designed to use OEM JK Tie Rod Ends from the drag link connection at the pitman arm. The Rock Krawler tie rod is a plug and play unit with no drilling or having to change the taper of the factory knuckles.
System Benefits:
1) Super strong tie rod assembly
2) Simple plug and play installation
3) No special tools required
4) Can be returned back to stock
System Includes:
(1) Heavy duty tie rod assembly made from 1 5/8 diameter solid alloy treated steel designed to accept OEM Tie Rod Ends at the pitman arm, (2) u-bolts to retain the OEM steering stabilizer, (2) jam nuts, and detailed instructions.
* Requires the purchase of two OEM Tie Rod Ends from the JK stock drag link at the Pitman arm location. The OEM part number is 52060049AE.
** Will require trimming of the supplied ubolts to re-use the OEM steering stabilizer.
*** Recommended wheel is a 17" diameter with a maximum back space of 4.5".
**** Please note: The Rock Krawler Tie Rod is the Strongest in the Industry, but it is not included under our Abuse Proof Lifetime Warranty
