1 - 20 of 35 Posts
Rock Krawler is happy to release our new billet aluminum stackable bump stops for JK's. The front JK units will also fit TJ/LJ/XJ/ZJ/WJ models. These will be a great way for people to tailer their up travel and allow freedom for changes in the future!
The front bump stops look like the image below. We offer (2) different sizes and again, then can be stacked on one another to achieve various combinations!
RK03320 are 2.5" in diameter and are 1" tall. They retail for $40 per pair.
RK03349 are 2.5" in diameter and are 2" tall. They retail for $49 per pair.
The rear bump stops look like the image below. We offer (2) different sizes and again, then can be stacked on one another to achieve various combinations!
RK03321 are 3" x 3.75" x 1" tall. They retail for $59 per pair.
RK03350 are 3" x 3.75" x 2" tall. They retail for $65 per pair.
For further information, check our website, give us a call or ask a dealer or wholesaler!
Rock Krawler
DAMN YOU!!!!! Stop putting out products I need, I am already broke!!!!
About the same price as the JKS ones, but at least they have the rear specific ones...
I'll be needing a quote on these...along with some spring retainers...
Keep in mind our dealers and wholesalers will be able to offer them cheaper than we do. We must support our dealers and wholesalers!
I will dig up our installed shot so you can see what they look like installed!
RK
Can you also show or explain how both these and the retainers would work together. I assume the retainers go on the flat outside area of the perch and these on the "bumps"
Thanks...
Hey jeremy, you ever come up with a new upper adj. bump stop that was as simple as that last one you had?
I'm not into the hydro bump stops, just a simple threaded rubber end with a small bracket to weld to the frame and two nuts. Got somethin?
Any updates on the pictures or the couple questions above???
Discussion Starter #12
Sorry guys.
Here is a 2" with a 1" stacked on top inside the front coil.
Here is a 2" single unit in the rear!
All hardware is counter sunk. Let us know if you have any further questions.
RK
Is it safe to assume the Rk Spring retainers then mount here...
Also, any word on pricing out to your vendors yet???
Thank you sir...
1 - 20 of 35 Posts
