First, I did search, but never found the answer..;)
Who is running RK deep sump? smash it up? Which skids does/doesn't it work with?
Finally, would you buy it again?
Sir
It works with pretty much any skid plate that does not go higher than the factory cross member! We have beat the snot out of ours and actually use it as our skid, but we would much rather have you hear from others... We have been moving quite a few of them....
We can tell you that your JK can go darn close to vertical without sucking dry or loosing drive... That is the real reason we made it...
RK
Thanks for the quick reply.
It should be stout enough, I had a twig puncture the stock one on a chevy p.u. I used to have. And i like how it'd keep the auto juiced up. Do you know if it works with the polypro trans skid specifically? I like their added clearance and strength factor.
