For sale is an almost complete lift from RK. Located in SoCal. Prefer local pickup. This is an amazing lift that offers awesome articulation. Included in the lift are:
(2) long travel progressive rate front coil springs,
double adjustable front track bar made from 1.5” solid alloy steel,
(2) high clearance-adjustable front lower control arms made of 1.625” solid alloy steel,
(2) high misalignment–adjustable front upper control arms made from 1.25” solid alloy steel,
adjustable front sway bar disconnects,
(2) long travel linear rear coil springs,
double adjustable rear track bar made from 1.5” solid alloy steel,
(2) high clearance-adjustable rear lower control arms made of 1.625” solid alloy steel,
(1) high misalignment–double adjustable rear upper control arm made from 1.625” solid alloy steel,
rear extended sway bar links,
long travel stainless steel brakes front and rear
The bushings on the front control arms have recently been replaced. I will also include 2 Bilstein 5100 shocks for the front. I am asking $1,100 OBO
The following parts are not included since they are on or welded to my rig at this time:
(1) rear independent 3rd link mount made of 1/4" thick laser cut steel,
(1) weld on rear axle cradle with adjustable anti-squat,
precision welded rear track bar relocation bracket made from ¼” thick laser cut steel
rear coil spring correction wedges
This kit includes the single upper control arm, so you can go this route, or purchase a pair of upper control arms ($249) and you won't need to purchase the 3rd link mount or rear axle cradle (truss).
In the near future I may be selling my rear axle which has the truss/track bar bracket welded on (and 35 spline Superior axles/ARB locker/Dynatrac diff cover/new ring and pinion) so if you want to go that route, stand by.
I just took this lift off, so pictures will be forthcoming.
Here is RK's description of this kit:
SKU: RKJK35XF+
Suggested Retail: $2,249.00
The Rock Krawler Wrangler JK 3.5” X Factor Plus System is the ultimate Suspension System for JK owners looking to run up to a 35” tall tire! Each and every part of the factory suspension is either upgraded or replaced. The steering geometry has been engineered to provide you with stock on highway handling characteristics. What makes this system special is what it can do for you when the pavement ends! The 3.5” X Factor Plus System off-road has all the bells and whistles to assure you of a great adventure. You get high clearance - high misalignment lower control arms front and rear, high misalignment front upper adjustable control arms, front sway bar disconnects, and long travel stainless steel brake lines to name a few. What makes this system really awesome is the independent three link rear conversion with adjustable anti-squat geometry. This is a feature no other suspension systems can match! Even the small details have not been over looked. The rear axle on the 3.5” X Factor Plus System is moved back 1” to allow for greater clearance between the tire and the factory rock slider for all you JK owners with the factory Rubicon Package. There are rear shock relocation brackets that move the rear shock mounting position up 2 inches for better ground clearance under the lower control arm mounts on the axle. This system is completely upgradeable to any other Rock Krawler Wrangler JK System and comes with our exclusive Abuse Proof Lifetime Warranty on all hard parts!
System Benefits:
-High Clearance Lower Control Arms
-Progressive Rate Front Coils
-Excellent Highway Ride and Handling
-Independent 3 Link Rear Conversion
-Adjustable Anti-Squat Feature
-Front Spring Retainer Clips
-Rear Shock Relocation Brackets
-Heim Jointed Rear Extended Sway Bar Links
-Rear Coil Spring Degree Wedges
-Bomb Proof Rear Track Bar Relocation Bracket
-The Best Off Road Ability of any Mid Arm System
-Allows for 35 Inch Tires
-Abuse Proof Lifetime Warranty on All Hard Parts
-Upgradeable to any other Rock Krawler System
Gunnery Sergeant USMC (ret)
phone number? Location? Read the rules or mods will be asked to delete this thread.
