Here's a quick and dirty install of one rock slider....
First, open the boxes... (duh)
Then using jack stands, I held the rocker up close to the Jeep to get the new body mount bolts and spacers installed...
I used painters tape to prevent accidental scratches on my paint while moving them around.
Then tighten up the body mount bolts so that the rocker is in it's final resting spot.
Now mark thru the holes where you need to drill
Now I backed off the body mount bolts so that the rocker came back down to give me room to drill the holes. I used a quality step drill bit (also called a Uni Bit)
Then I installed the nutserts - they are cool - using the fancy nutsert install tool included with the kit.
Then after tightenting the body mount bolts again to get the rocker back to final resting place, my wife installed the bolts into the nutserts. Remember to remove the painters tape before this step - you won't be taking them off again. Also remember to install the rubber end stops into the rockers before this step - you can't install them once the rocker is on.
Finally install the rubber caps over the bolt holes and we are done, done, DONE!
