Robb's 08' JKU Rubi Build
97066 Views 430 Replies 74 Participants Last post by  Robbs2008JK
5
Robb's 08' JKU Rubi Build(AKA Sarge)
New to the form but not new to the Jeep world. Owned a TJ for 8 years and built that up. Had to break down and buy a JKU. Have 2 kids that I want to take wheelin. So found a 08 JKU Rubi that is extremely clean and only 23,500 miles on it. Did a ton of research on lifts and long arm kits. Came down to Poly and Teraflex. Ended up going with the Teraflex do to cost of Poly. Did the 6" elite long arm from teraflex. Also did the matching Fox racing resi shocks. Front inner axle tubes and inner c braces. Also installed the spin tech locking hub conversion and up graded to all new chromoly axle shafts front and rear. Added 37 13.50 17 Toyos with race line monster bead locks.
Jeep rides better than and handles like a car. Very pleased with it do far.
Future add ons will be custom built sliders w/ PSC rocker armor, customer bumpers, on board air, gears, and 1 tons.
Enjoy!
Before any mods. The way I bought it
The start of the Madness
41 - 60 of 431 Posts
Its always great seeing all our products in use, thanks for posting!
Using your diff covers and front off set tie rod kit!
4
Got the control arm skids welded on and modifed the Teraflex inner c-gussets for the new Artec inner c-gussets to go over the top of them.
Enjoy!
Fitted the upper inner c-gussets and finished weling them all in. Next is psint and installing the RCV axle shafts in 300m
Looking damn good. Very nice fab work. The coils must come very close to touching those upper c-gussets, no?
Tohe coils are close but will clear. Will be getting the front end all assembled this morning and back under the jeep
5
Got the front end done and took the beast out for a drive. Aligned this morning and fkexed her out again. I most say I like it.
Started doing the rear bumper today. I also relocated the rear swaybar where in mounts to the frame. I pushed the rear axle back and 1 1/2" so the endlinks were rubbing on the axke housing. I cut out the rear frame cross member and cut the rear frame rails to give me a tighter fit on the rear bumper and better departure angle. Will start on the rear bumper tomarrow.
Enjoy
Great looking pics of our armor kit. Well done on the install. Do you mind if I post them up in our gallery?
Not at all. Love the armor kit. Cant wait to go test it out. Thanks for making a incredible product. Will recommend it to anyone.:rockon:
4
Started the rear bumper. Have a lot of cutting to do and tons of welding.
I like where this is going, looking forward to the finished product.
5
Worked on more the bumper. Wanted to protect the corners when coming off ledges
What are you using for your tire carrier hinge?
5
Did a little more work on the bumper today. Will be doing the spindle design tonight fot the carrier
Enjoy
I didn't think you were allowed to weld in cali??
3
Welded up all the seams last night. Will smooth out all the welds sat night.
Got the bumber all smoothed out and mounted on the jeep. I used 2 9/16" grade 8 bolts going through the frame and also sleeved the frame where the bolts go through the frame. Also doing 4 counter sunk allen head 1/2" bolts going through the bottom of the bumper into the frame. I still need to add the reciever and clevis mounts. Then will start building the tire carrie. Takeca break on it firca few days. Got bit by a black widow or something on my right knee yesterday and haveca nice swollen knee that I cant bend and is killing me in pain. But shoukd be back to par in the next few days.
Enjoy!
