Wow, you did a great job man. Sweet, sweet build.
Wish I was a DIYer. When I get a real job and house maybe one day I'll learn to weld.
I run that. Get it tig welded for extra strength. Or you can get 1.25" Dom threaded from a supplier. Forget the name but I can find it if anyone would like it.Ruffstuff make a DYI universal kit for $125. Comes with offset 1 Ton tie rod ends tube inserts, jam nuts and 1 1/2" x .250 wall DOM Tube
Here's the link
http://www.ruffstuffspecialties.com...tuff&Product_Code=TREOFFK&Category_Code=STEER
The u-joint was a Presision cryogenic Joints. Problem was the shafts were bottom out on each other causing the joint to fail. The front housing is sleeved and gusseted and I am going to fully truss tge front and rear. The 44's should hold up ok with my driving style. I drove a 2001 TJ fir 8 plus years with a D30 in the front and D44 in the rear on 35's and never had a issue. Key thing is to pick the right line and nit try to prove anything. I will winch or stack before I get to the point of breaking.Nice build. Yeah I have a tf 4" lift. 6" is really ideal I think.
I thought chromoly was a very good idea to go to for all your shafts. How did you brake the cross on the joint like that? I did that to a basic moog joint but I wouldn't have thought of that happening with a chromoly shaft and joint.
Do you think you will consider rcv's now? Edit - I didn't realize there was a 2nd page. So you have rcv's. good stuff.
I run bushwackers too. Seem to good. I like them.
So 40's on the 44's? Wow. Let me know how that goes. I have thought of running tires that big but wasn't sure of the needed offset for the tires and its effect on the unit bearings and overall strength of axles for tires that big.
http://www.fourwheeler.com/techarti...king_hub_conversion_kit_jeep_jk/photo_05.htmlThe outers are different. It uses 30 spline outers that are 9.94" long. No machining required
