I'm currently installing the RK X-Factor 5.5" with 3.5" springs. I also have the heavy duty tie rod.
My problem is this. The front RK trackbar with the heim joint does not fit into the RK lower trackbar bracket. It's not even close.
The rear track bar bracket is plenty wide, but the front is obviously built smaller. I've searched the web, and have not found an answer.
I can't be the first to have this issue. What am I doing wrong, or are there two styles of front trackbar brackets? Any help would be greatly appreciated.
Kevin
Kevin
