Installed RK 2.5 Max Travel - Now Questions...
I finished installing my RK lift this past weekend and I'm curious... the rear swaybar links are HUGE... and they lean forward a good bit when compared to the front links, which are pretty much straight up.
Is that normal or did I get mixed up with the wrong links?
Additionally, I set the front trackbar to the length recommended by RK, but the front axle still sits way to the driver side. Do I need to adjust the trackbar out some more or could my stock drag link be fighting the trackbar for front end alignment? My thought is that the drag link would just pull my steering wheel offset, but I've not done a lift with this much attention to detail before, so I just want to make sure I've got it all right.
