1 - 2 of 2 Posts
Hello all,
I started installing the River Raider Jack mount on my roll cage and thought I would pass on a little bit of my experience in case you plan on doing the same. The kit includes a tap which you use to thread the pre-existing holes in the tubes. The thing they DON'T tell you is the bolt for the seatbelt extends quite a ways into the tube directly opposite the hole. If you keep running the tap into the hole, it will get harder than usual to turn and break! Don't ask me how I know :pissed: And it is QUITE the challenge to get the broken tap back out. :bawling:
Hope this helps someone avoid the same problem. I have to go get another tap to finish the job.
Merry Christmas,
Allan
1 - 2 of 2 Posts
