1 - 9 of 9 Posts
Hey guys,
You may know us from our popular JK supercharger program. We introduced the TJ kit as well - but revisited the Electronics - RIPP now offers a killer TJ kit.
2005-2006 Kits include:
  • RIPP Supercharger Drive System
  • RIPP Water to air intercooler system with integrated water tank
  • RIPP Front mounted Heat Exchanger
  • Hella Intercooler water Pump
  • By Pass Valve
  • Larger Primary Injectors
  • Air Filter
  • Belt
  • Hardware
  • Couplers
  • PCV Valve
  • RIPP MAP sensor
  • Diablo Sport Predator Pretuned
  • 1 year warranty
RIPP Superchargers 2005-06 TJ GEN2 6spd 240whp 300ft/lbs of Torque - YouTube
We now have nearly 1000 JK Supercharger kits on the market and several TJ's running the upgrade. We feel this will fit right in with your larger TJ's needing easy safe power. -
Questions Welcome
That is a very tidy install. Gonna do a kit on my JK next spring.
Ross, I'm seriously considering this for my new 04 LJ build... but you say 05-06... I thought the 04-06's were all the same, then 01-03 and then older were different programming, etc. Can you clarify?
Also, how is it to install? As easy as the JK, or completely different?
The kits fits as its posted in these pics - you will need to tune with a plug and play Unichip, instead of a supplied Diablo sport and RIPP tune..
RIPPTECH
I would go with RIPP on everything... if only they could get through carb crap bs...
California... it sucks to live in such a socialist democracy...
Sent from my C771 using Xparent Blue Tapatalk
RIPPTECH
That stinks, I was hoping to be able to have your tune rather than a generic Unichip tune. How much of a difference does it make between the two? :beer:
You wouldn't use the generic tune - you would have it dyno tuned locally :)
RIPPTECH
1 - 9 of 9 Posts
