1 - 20 of 69 Posts
View Full Line of Rigid Industries Here
Lots instock and lots on order. Contact us for the Rigid Industries LED Lights you are looking for.
Rigid Industries Dually-LED Light
A 4 LED light in a compact 2x2 package that can be used for anything from a reverse light on a truck, a handlebar light on a Motorcycle, to a flood light on a trailer. With 1000 lumens of light, this small light has the same light output as a 50W MR16. At a small 3"-3" this light can fit anywhere. Pulling only 10W you won't find a more efficient, compact light source in HID or halogen. This light pulls half of what your stock turn signals use
Rigid Industries Dually D2 LED Light
The Dually D2 Series LED Light from Rigid Industries is a compact 3 inch by 3 inch lamp containing 6 LED's, that can mount almost anywhere. These lights are the pinnacle in effieciency, providing 1300 lumens of light and pulling only 15 watts of power, which is about half of what your stock turn signals use. You won't find a more efficient, compact light source in HID or Halogen. That combined with the durability and long life span (50,000 + hours) of LED's, this is the obvious choice. Easily mounts on motorcycle handlebars, as flood lights or on your trailer. Kit includes plug and play harness, mounting brackets and mounting hardware.
Rigid Industries E-Series LED Lightbar Kit
The new "E" Series high intensity LED light by Rigid Industries are rated at 93% optical efficiency. 80 LED’s with a 50,000 + hour life span and easy 2 wire install. 8" of flood reflectors on the outsides of the light and 32" of spot reflectors on the inside half of the light. This will optimize both functional light spread and light distance for increased visibility. Reflectors available in both pencil and flood beam more light with less power, heat and size. If one LED fails the other LEDs will not greatly reduces eye fatigue.
Rigid Industries SR-Series Hybrid LED Light Bar
Rigid Industries' SR-Series, Single Row LED Lightbars measure only 1.5 inches in height and feature Rigid's Patented hybrid optics that allow a wide array of high performance flood and spot lighting for multiple vehicle lighting applications. Rigid LED lighting is the pinnacle in efficiencey by providing high lumen output with low power draw. If you're looking for high quality, durability, longevity and high performance, then Rigid SR Series LED Lights are your perfect choice.
Discussion Starter · #6 ·
pm me a price for ....
-pair of D2's
-30'' light bar
-50 '' sr light bar
... 98279
thanks
PM Sent. Be sure to let me know if there is anything else we can assist you with.
These are the hottest thing on the market in LED Lighting. Let Baseline 4x4 Outfitters quote you on this product.
I am interested in a pair of D2 driving beams.:)
Discussion Starter · #15 ·
1 - 20 of 69 Posts
