1 - 8 of 8 Posts
Hi all,
I'm planning to put a Rigid 10" E-Series Light bar on the front bumper of my jeep. I currently have a set of dually spot's on the a-pillar. What would be the best beam pattern for the light bar to be most useful on the trail? The bar comes in a spot, flood and a combo spot/flood pattern.
Anyone with experience with the different patterns or this light bar in general please chime in!
Thanks
Hi all,
Thanks
I have a Rigid bar in Combo beam, but wish I'd gone with their spot only pattern.
With lights in general I've found spot beams (and driving beams) light up both close and far, whereas flood or combo patterns light-up close-by brush that aren't needed, like tops of trees, etc.
I'm currently running 4 D2's (all flood) and a E series 10" light bar (spot). It's a prefect setup for where I wheel. I'm always in tight wooded trails here in Cali so I don't need miles of light. The main reason I went with the light bar in spot was because the 4 D2's are plenty of flood. I wanted a little bit of distance. If I was to do it again I would have got the new SR series with the specter optics. They put out more light, I was a tad disappointed in the amount of light that the 10" e series puts out. The D2's walk all over it.
I've seen both. Personally I'd recommend you put a set of D2 floods on your bumper rather than the 10". The D2's are amazing. If you had 1,200 I'd tell ya to get a 50 inch but short of that go with a set of duallys or D2's.
Thanks for the responses, JK Vick where do your have your D2's mounted?
Also, I noticed on the SR series w/ specter optics it only comes in a driving pattern which seems the equivalent of a flood pattern.
I have one set on the A pillars and the other on the bumper. I would also recommend getting a set of D2's over the 10 inch.
1 - 8 of 8 Posts
