1 - 9 of 9 Posts
· Registered
I did a search nothing came up. So I'm trying to remove my steering wheel so I can get my dash out, dash is hanging up on it. Can't for the life of me figure out how to get airbag off to get wheel off help plz.
Sent from my MB886 using Tapatalk 2
· Registered
There are three clips you access from behind the spokes. I took a long 90* pick and pulled down on the clip as I kept tension on the airbag to get it to pop off.
It'll be a bit of a struggle probably if its your first time.
· Registered
I used my Swiss Army knife, (Victorinox) flat blade half out. The hard part is turning the wheel to get each clip to the top when the engine is off while the wheels are on the ground.
When pulling the airbag, it is always safest to have the battery disconnected... just in case.:th_pray:
1 - 9 of 9 Posts
