Removing Rear Plastic Panel
11K views 4 replies 5 participants last post by  stanman
#1 ·
I would like to remove the right rear plastic panel to see if there is sufficient room for a little mod I have in mind. Can anyone tell me the best/easiest way to do this? Looks like it's in two pieces. This is a 2012 JKU.
Thanks!
#5 ·
Jason Mac nailed it.
If you're careful when separating the outside piece at the top you won't wreck the little tabs. I've had mine apart three different times and haven't had anything break.
I do keep forget the 10mm nut that you can't see until you crawl up inside and look behind the upper part of the outside panel.
