1 - 2 of 2 Posts
Time Required:
5 min
Tools:
Interior Panel Removal Tool
Procedure:
1. Carefully slide removal tool between top left corner of access cover and inner tailgate.
2. Pry slowly until metal tab (attached to access cover) frees itself from inner tailgate.
3. Carefully slide removal tool between bottom left corner of access cover and inner tailgate.
4. Pry slowly until metal tab (attached to access cover) frees itself from inner tailgate.
5. Access cover will be free. Pull away from tailgate from the left side.
Notes:
DO NOT pry from the right side. Plastic tabs will be damaged.
Related Parts and Part Numbers:
04589584AF - Power Actuator, Tailgate
04589586AF - Manual Actuator, Tailgate
Discussion Starter #2 (Edited)
Use for installing power lock actuators, aftermarket tailgate accessory installations, wire harness access, etc.
More in-depth write-ups regarding the 2013 Wrangler Unlimited (JK) Sport will follow as I continue to modify or install components.
1 - 2 of 2 Posts
