2007 unlimited rubicon w/ mopar remote start....Used the remote start in the morning before going to work...It worked fine just like it has every winter since we bought the jeep new in 2007. Hit the remote start before leaving work. Jeeps starts and run for about 3 seconds and shuts off then restarts and shuts off 3 seconds later. It did this three times. Then it wouldn't work again untill I manually started it. Now it does that everytime. starts runs 3 seconds shut off 3 times then it's done..
Has anyone else had this problem or know of what to look for??
P.S I have tried the other remote just incase of a weak batt in the remote might be the problem..I've also unhooked the jeeps positive batt cable for about an hour and reconected it. Did not help..
Sounds like there is a problem with the module that emulates having the key in the ignition
I had a very similar problem with my aftermarket remote start, and it usually did all that shit when the doors weren't locked.
Take it to get reprogrammed. Warranty will cover it.
