I picked up some relays today, and ended up getting SPDT relays/sockets since they were dirt cheap ($2). They're exactly like the standard R51 automotive relays I've seen except for the 87a contact for normally closed circuits.
Now, the only question I have is this:
On a R51 SPST relay, the ground (black) is on terminal 85 and 86 goes to the switch. On the relays I bought (SPDT), the tabs are reversed; ground is 86 and 85 goes to the switch. Does that sound right? That's how they're lined up when putting the socket on... If it's not right (and 85 really IS my ground), I can just swap the pigtails around. But I'm not sure if it's supposed to be this way or not...
-WRM
If it is sold as a bosch type, it is standardized connection for the contact locations. They are sold as different than RS1 as far as standards are concerned, however they both will work as long as the power #'s are the same. The SPST(Single Pull Single Throw) vs SPDT(Single Pull Double Throw) is a different thing. One has one connection inside vs two in the other...
http://en.wikipedia.org/wiki/Switch#Contact_terminology
