1 - 20 of 173 Posts
ReconJeep
· Registered
Discussion starter · #1 · (Edited)
I just got this 2016 JKU Rubicon in the Mojave Tan. Not my first JK. I had an 09 JKUR when I was overseas. Now I'm back in NC. I got it on a great deal because I wasn't in a hurry to get one. Ran into a couple of other ones but there always something not right. This had only shy of 2000 miles and the price was a steal. It has the two tone leather interior. Guess previous owner had financial or psychological issues and had to give it up. My gain! This is not going to be an extreme build. I already have a Hummer H3 on Dana 60s and 40" tires I use for wheeling. This is going to be my daily driver with off-road capabilities. More like an overland build with top notch protection. I'm aiming at a 2"-3" lift with 35" tires on bead locks. I already set my credit card on fire! :D Stay tuned as parts come in and I start to build it up.
"Ex Umbris Venimus"
Discussion starter · #2 · (Edited)
This is a pic of my 08 JKUR I had overseas. It had many of the same parts I'm planning on adding to the new rig but with no lift. It had to fit in a very low garage so I just limited the up travel to stop rubbing. I won't be doing the slantback hardtop on this new rig.
"Ex Umbris Venimus"
Discussion starter · #3 ·
Installed the JWS led headlights as well as some led markers. I also have the JWS led fog lights but ran out of time to install them.
These came in the mail from Molle Platform Solutions and can't wait to get them on during the weekend.
Discussion starter · #4 ·
Started installing the Molle panels. These things are so well thought out and built. These rear panels are awesome because they serve multiple purposes. The obvious ones are the Molle on the outside for pouches and the ability to use it as a container for loose objects. The not so obvious is that the forward brace also has Molle which allows you to add anything you wish that's accessible for the rear seat passengers.
The folding Molle shelf is by far the best thing this guy has designed. I have the same one on my Hummer and it rocks! I plan to add a removable trauma kit and other smaller amenities. I'll be installing the roof panels later today or tomorrow. Family duties are calling.
Discussion starter · #10 · (Edited)
Got some more goodies from Molle Platform Solutions. This is something I came up with and have been brainstorming with Alan of MPS. They're small Molle panels that bolt up to the door retention strap loop. The main reason for designing these was to have a place to keep spare mags, but you can pretty much use them for whatever your needs may be.
There's three different designs we are testing. The first option is whether you want to have three rows wide or four rows wide. The second option if the top row is standard sized or 1.5" wide. The reason for the 1.5" width is to simulate the size of most belts. I wanted this because I can clip onto it my EDC mag pouch which is also designed for a 1.5" belt. This way it's not loose and rattling. You can mount the mag pouch either inside the panel, so it more snug, or outside if the pouches is larger or a piggyback style. If you get the three row style you can run three pistol mags or a combo of one pistol mag and a rifle mag. If you get the 4 row you can run two rifle mags or two piggy back mags. With the three row you can still use the factory net pocket, which I find pretty much useless. I'll decide after some extensive testing.
This is the three row version with the standard size Molle.
This is the four row with the 1.5" width top row to match my belt.
This is the three row 1.5" width mounted on the drivers door.
Here you can see my EDC pistol pouch clipped to the inside of the panel and a piggyback rifle/pistol Taco mounted on the outside. The Tacos are awesome because they expand to just about any rifle or pistol mag. You can also put your phone in the rifle mag and a light or multi tool in the pistol pouch.
Discussion starter · #12 ·
Installed the Off Road Evolution oil pan and transmission skid plates. These things are very well designed and strong as hell. Now to figure out what I'll do to protect the exhaust. It makes sense to get the ORE one too but they say it doesn't work with long arm kits, which I plan to get. Anyone know if it's compatible with the Teraflex LCG long arm kit?
"Ex Umbris Venimus"
Discussion starter · #17 ·
Finally assembled a decent trauma kit. I spend a lot of time at the range and it's only a matter of time before a negligent discharge occurs. Also in the wilderness, anything can happen and usually Murphy is nearby to throw a monkey wrench to make things worse. After several training classes, I've built up a list of gear I know how to use and not some generic bought first aid kit. First pouch on the left is for splints and bandages for sprains and broken bones. Second from the left is for extra dressings and other duplicates in case a multiple casualty situation pops up. Far right is the main kit that is removable from the panel so you can take it with you. It contains all the more serious gear like tourniquets, NPAs, chest seals, coagulant dressings, sterile dressing, shears, gloves, finger light, etc. Second from the right is a folding litter that can be used by one or more people to carry the patient. On top of that is a strobe for signaling location if needed. There's some work gloves in case some work needs to be performed to access or retrieve the patient, that sterile rubber gloves can't handle. I think that's everything. :D
Discussion starter · #19 ·
Got a ton done today. Installed a Lange hard top hoist. Got the hand crank version. Couldn't justify the extra cost of the electric hoist version for twice a year that I would use it. I also prefer the hand crank version because you can feel tension on the cable if something is hung up. Works very well but is one pulley short. Added the extra pulley because the angle of the cable was getting in the way. Took advantage that the roof was off to do some mods to the rear molle panel.
Discussion starter · #20 · (Edited)
Since I had my hardtop off with the hoist, I took advantage to do some mods to the rear Molle roof panel. I drilled and secured a fire extinguisher so that it could be accessed by all the occupants. I have a few more in the rear but I wanted one located so that everyone could access it, in case of an accident where the occupants may be pinned down.
I also added some Camelbaks and headlamps that double up as map reading lights for the rear occupants. The new Camlebaks have d-rings that coincide with the headrest posts. It's so easy to pop on and off for either wearing or refilling. The Petzl headlamps can cycle through many intensities and colors depending on need.
1 - 20 of 173 Posts
