Your fuel overflows too? Mine has done it since I got it, about two years ago. Im not under warranty any more. Is there anything I can do?X2. I had my gas tank replaced under warranty recently (fuel overflows)......
I have read that the warranty on the gas tank was extended specificly to cover this issue. Talk to the dealer...I think it's covered.Your fuel overflows too? Mine has done it since I got it, about two years ago. Im not under warranty any more. Is there anything I can do?
The bulletin is 14-001-11I have read that the warranty on the gas tank was extended specificly to cover this issue. Talk to the dealer...I think it's covered.
I need that done asap! Guess I gotta get to the dealer and check out my long list for the JK!The bulletin is 14-001-11
SUBJECT:
Fuel Spit Back During Refueling (Unlimited Time And Mileage Warranty Extension)
OVERVIEW:
This bulletin involves replacing the fuel tank if the condition occurs.
MODELS:
2007 - 2008 (JK) Wrangler
NOTE: This Extended Warranty Bulletin applies to vehicles equipped with a 3.8L
engine (sales code EGT) built between March 1, 2007 (MDH0301XX) and
March 31, 2008 (MDH 0331XX).
SYMPTOM/CONDITION:
Some customers may experience a fuel spit back condition during a refueling event.
DIAGNOSIS:
If the customer experiences the symptom/condition, proceed to the repair procedure.
Bottom line: If you are having the issue, they will fix it, otherwise- don't be looking for a free gas tank. =p
Im a service writer.
My question is how in the hell is it only 07-08's that get it. Nothing changed in the fuel system after 08... My '10 spits fuel at me all the timeI need that done asap! Guess I gotta get to the dealer and check out my long list for the JK!
think your under the wrong topic but in any case , if fuel is spitting back the check valve in the tank isnt working properly, not to be confused with fuel tank hard to fill. the 2 options to fix is replace the fuel tank or get the fuel filler neck from the x32 extended warranty from an 07-08 if it will fit the sameMy question is how in the hell is it only 07-08's that get it. Nothing changed in the fuel system after 08... My '10 spits fuel at me all the time![]()
If its a recall warranty don't matter.My '07 that I just bought does this but it out of warranty. They won't take care of it out of warranty right?
