Me to.I got a (second) letter about the tow bar that I don't have. Ha ha.
X2. I had my gas tank replaced under warranty recently (fuel overflows) and the dealer did the auto trans "hot oil" flash. They said they didn't know about this yet.FWIW, I was at the dealer yesterday and they stated that they knew nothing about this recall as they havent heard from Chrysler yet.
Stated they wished Corp. would let them know about recalls before they put it out public.
Yeah, me three. I took mine in for that one, the transmission flash, a check engine code p0108, and my rear locker was not working (again). So, they fixed (I Hope) the recall for the tow bar I did not have, the flashed the computer (changed the shift points on the transmission, changed when the lockup happens, AND it lowered the charge voltage on the alternator from 14.1+ down to 13.6-13.8v).I got a (second) letter about the tow bar that I don't have. Ha ha.
the problem is the inner fender liner shit rubbing against the brake line. its definitely an issue, as one side of mine was wearing a bit. the other side was clear by a mile.I pressed my local dealer on this. They dug deep and found that yes, it does exist. BUT... It ONLY APPLIES TO RIGHT HAND DRIVE VEHICLES. Not only did they admit that it exists, they printed and gave me a copy of the TSB!!! Not that it did anything for me. It showed that the right hand drive models have the brake line clipped to the frame in a spot that allows it to rub against the steering shaft. So, either have it repaired, get a lefty, or never turn, just put it in low range and climb over everything in your path.
This effect left hand drive vehicles as well as right hand drive vehicles. Here is a photo of one that has been trimmed (by the owner) already. Mine was rubbing pretty bad.Anyone have a pic of this area??
And am I confused, but would'nt most of us in the US NOT have a Right Hand Drive vehicle?????
Thanx
YupAwesome. Thanks For The Pic.
Is that on the passenger side front?
Thanx Again
I got the letter yesterday; I went out and checked my fender liners, and they were not rubbing in any way. One is about 1/4" from the brake line, but I cannot see it ever rubbing. This is not worth taking several hours to drop off the JK at the dealershp for them to look at and make any changes. It can be fixed in about 20 seconds with some snips and some common sense. However, if you already have an abraded brake line, that is a different story, I would take it in to get it replaced.Recall letters are going out now.
Recall# K13
We just got the parts today.
