i need one for the body mount side/passenger side (not the axle-mount/driver side).I believe most everyone except skyjacker. Skyjacker has solved their problem with a brace that goes from the pumpkin to the track bar mount. really makes it strong.
i'm looking for REAR body mount side.Rubicon Express does . Its drops the track bar 3" from the OEM location. I think that Poly does as well...Sure there are others, but dunno who? My jeep rides and steers great with the front and rear dropped trackbar brackets. Able to use the OEM pitman arm w/o going to a dropped arm which (I believe) keeps the steering in better geometry than the TJs that I've had with dropped pitman arms...Probably starting to go off topic...woops!
I have the newer TF axle mounted kit. I originally had the frame mounted bracket similar to the one pictured above.this what you're looking for?
http://www.jkowners.com/forum/showthread.php?t=678&highlight=bds+bracket
RE and Poly have both front and rear tb brackets...that come off of the frame rails
good read there. i think everyone should read that post! thanks for the info!If you're interested this post deals directly with the question of track bar relocation brackets. Its from my Poly Review article so there's a bit extra in there too (if you want to skip that start at the third paragraph), but it'll tell you all you want to know.... well, probably:laughing:
