1 - 12 of 12 Posts
Running 37" tires on D30 and have been looking for a reasonably priced D44 that I could build over time. No luck so far. So I am thinking about buying the RCV's for what I have. I guess my next weakest point is my R&P. How likely am I to break my R&P? and has anyone on here actually ever broken one? Stock motor, stock 3:73 gears (going to 5:13 as soon as I can). Pitch in boys, I know everybody has an oppinion.:beer:
If that's the case, don't lock it. At most, your spider gears will take a shit before your R&P does. If you do lock it, with the tiny 5.13 gearset for the D30, it'll be the weakpoint. I'm on a Detroit locked D30 with 4.88s and 35s. But, I'm easy on the pedal.
Take my advice, keep on breaking stock shafts. I break stock shafts a few times a year. Better than the R&P. There's your answer. Don't spend $1,000 on shafts and rip your R&P the first time out.
Think of the shaft as a fuse that blows, saving the more expensive parts.
If you add up what you've spent on shafts, perhaps you would have more $ for a new axle/diff, etc...
Once the diff can handle more load, you can upgrade the shafts and u-joints, etc...to match, etc.
With all that snappin goin on though...keep a fuse in the drivetrain where it makes sense.
We used to use hub fuses for example....so we'd blow a cheap easy to swap out lock ring type thing instead of an expensive, hard to replace part....the trick is to get the "fuse" to be just a LITTLE weaker than the NEXT weakest part.
:D
I ran 37's on my TJ d30 which had a lot smaller ring and pinion and was low pinion and only ever broke ujoints...
i personally agree with everyone about just leaving the stockers. I say just carry a set of spares...
that being said, the D30 ring and pinion isn't THAT small. compare it to a TJ's or older styld D30... even the 5.13's i put in weren't that small compared to the TJ's.
I blew 3 axles in 1 week. The first one I was spinning and bounced the front about 2 feet and snapped as soon as it came down. The other 2 I was creeping at full turn trying to climb a rock and broke them real easy. I think I will wait to find a D44 cause I would hate to have to spend $600 + to replace a R&P. And I refuse to go down a tire size.
Well A) you shouldn't bounce the truck and B) you shouldn't be at full lock trying to get on an obstacle.
Reposition yourself if you have to.
Discussion Starter #11
a) some times shit happens
b) you try holding those 37's to keep them from turning with that pos steering pump
c) you shouldnt sas your elders boy
:thefinger::beer:
Haha no disrespect, just be easy on her!! She does love a beating from time to time, but there's a fine line...
1 - 12 of 12 Posts
