1 - 2 of 2 Posts
When accelerating and my engine/aftermarket exhaust creates a little vibration, I get a slight rattle noise from, best I can tell, gear shift. Seems I had read some time back that another member was getting a slight rattle noise from the gear shift area. It's not anything mechanical from what I can tell. When I grad the gear shift it tends to damped the noise.
It's got to be something down in the trim/housing at the gear shift. When accelerating and the mid range RPMs the sound occurs and I can simply put my hand on the gear shift and the rattle noise is dampened. I can't tell if there is a piece that may be down in there up against the shaft of the gear shift that is making this noise when there is the vibration from the engine RPM/exhaust or what. Gets very annoying though.
Any ideas?
Discussion Starter #2
Anybody have any ideas?
1 - 2 of 2 Posts
