1 - 20 of 26 Posts
Ended up using the stock frame cross member....
Ground out the frame rails from it and then used a extension hitch and cut off the length I needed...
Flipped the cross member over so it went up instead of down then notched it for the hitch....the pic of the hitch does not show all the gusseting and overlapped steel that was done....
Flipped it cut off the body mount pockets ground frame smooth and then put the cross member in, started the angles and plating I'll finish it tomorrow or Saturday.
Putting angles on it to slide off stuff and will do the sides after I finish plating in the inner sides...this thing will not move....
Here's how it started
Here's how it looks
28" from ground to hitch which is lowest part aside of frame rails
Giutted the rear jack storage to allow the clearance
This shows how far up flipping the cross me bear and then notching the hitch in gives you...its at least 8"+ higher now the ground clearance back there is huge.
Discussion Starter #2
Its not done, still need to finish plating it in and do the side sections.
Also exhaust has been put in front of axle with dump and evap is relocated to under axle....
Discussion Starter #5 (Edited)
Tailight design is mine and yeah body mounts are going back. They will be in front of the cross member. I'm cutting a hockey puck down to size and using that as well as replacing all the mounts with hockey pucks. Going to ace body jiggle for the cage to frame and up front I need to inboard the mounts anywase I'm chopping the grill like a CJ and it will tie into the lines of the poison spyder bumper...
Actually finishing the shaping on the tailight plates and will be selling them shortly...as well as other jeep stuff from us and others...
Coming from a more simplistic rock crawler angle versus the goddyness that plagues a lot of stuff...
Let me know when you are ready to sell them. I would like a set with just the lower hole for the reverse light so I can mount my ORO TJ/YJ LEDs.
Discussion Starter #10
Thanks .
Yeah if I end up stretching it 8" this will be perfect...
Coilovers through the jack hole and bumper can cap at frame where body angles in from being cut...
I'll do a small build thread as it goes I'm doing all side armor, fenders and rockers as well as arms and linkage.....
Discussion Starter #12
I like the idea but i would rethink the hockey puck idea.
Hockey pucks all the way around and frame mount a new cage....that's the plan....
I'll get la king pucks just to stay socal loyal....:thankyou:
I've seen guys use hockey pucks before and all have cracked and/or shattered, don't use them
Discussion Starter #16
Then I will find some low profile ones from the junk yard or catalog and make em...thanks for the heads up...never had a issue on the race truck but good to know....(actually when it went full race it was hard mounted so pucks were on for short period)
Just saw your from Canada so I think the cold might play a role in the rubberized material getting hard and fracturing instead of staying rubbery....
Discussion Starter #17
Did some work got sick so ill finish up this weekend.
Heated the panels and bent them in....
i am def interested in the tail lights as well.
Would it be possible to get the plates smaller so they fit right in place of the stock lights and only have one cut out hole on each plate?
Discussion Starter #19
As soon as I get some time I'll go measure a template and see if it'll work. If I remember right it will be fine....
Where should the hole be centered top or bottom....I say top then you can add another light or angled rock light below later if wanted...
Discussion Starter #20 (Edited)
Got the rear panels bent and welded along with caps on rail. I'll work on it some more wed/Thursday been really sick and kids too....
1 - 20 of 26 Posts
