N
Guest
i have a 2012 with 60,000 miles started to overheat. i changed radiator cap, high speed relay,low speed fuse is ok, changed thermostat, and fan runs off direct 12 volt power. what can be the reason its not running. i changed everything that the code said can be wrong
I just had this issue and it was my tipm. Hopefully it's not that because it was a little over 700 bucks and that included a healthy discount
N
Guest
i just replaced the tipm about 5000 miles ago thanks man it could be that got a remanufacture one
I bought a new one for that reason. If you know someone who has the same year model take your fan out and hook it to their jeep. We also took my buddies tipm and put it in mine and the fan worked
